Hydraulic fluid leak, what's this?
  • Colesy
    • Feb 2009
    • 2980
    It looks like a hydraulic hose is leaking, but I'm concerned that whatever the hose goes into might be at fault, so can anyone tell me what this is?
    Is it likely that it's just the hose that is leaking or could pressure be causing the fluid to spread up the hose?
  • Colesy
    • Feb 2009
    • 2980
    Have realised that the pictures aren't very good, they were taken to the n/s of the engine and the leaking hose (I think) goes to the hydraulic reservoir. So in the pic the drive shaft you can see is the n/s front.
    • shaun5
      • 1610
      that is your brake bomb, try a new jubile clip, it should'nt be under high pressure. Have you got the autocheck going off all the time?
      • Sleeper_Avant
        • 2372
        i vote for the pipe going pourus, as it seems to be most of the pipe length, if it was the lower clip (my 1st thaught) gravity would just make it drop down
        1993 URS4 Avant Emerald Green 350+bhp
        1991 Ford Sierra Sapphire 4x4 in Magenta
        BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
        • Sleeper_Avant
          • 2372
          im going to google the S2 brake system setup as ive never actually been under an S2 bonnet and dunno the brake layout, i may well be wrong lol
          • Colesy
            • Feb 2009
            • 2980
            No brake waring lights or anything else with the autocheck. Sleeper have you found a diagram of the brake system? Might just order a replacement hose, does anyone have a psrt number?
            • Sleeper_Avant
              • 2372
              i havent found anything that was of any use as your picture means nothing to me as ive never been under an S2 bonnet.........
              but i think this looks and sounds familiar from what others have said!
              http://www.ebay.co.uk/itm/AUDI-80-2-...item337738f158
              • Sleeper_Avant
                • 2372
                Or, theres a few lads breaking S2`s at the minute, PM them and ask for the part in the picture, you will defo get what you need then
                • s2_bo
                  • Oct 2005
                  • 6067
                  That hose leading to the top of the bomb is probably just worn because of the angle and age.
                  You can replace it with any other 8mm oil rated hose or fluoro silicone hose. It could also just be that your clip is lose but the fluid your seeing is power steering fluid which might need topping up now. its G004000 mark 2 from audi or Febi 6161 from GSF or ECP.
                  91 S2 coupé - RIP
                  98 S8 - Luxury barge
                  • S2TORNADO
                    • Jan 2008
                    • 620
                    as someone has said. looks like the top of the brake bomb.
                    follow the pipe upwards and it should go to a tee-junction. one side runs to the bottom of the hydraulic reservoir, the other side runs along the top of the steering rack area and joins onto the rack on the drivers side with a banjo fitting.
                    sometimes the pipes deteriorate and leak.
                    • s2_bo
                      • Oct 2005
                      • 6067
                      f you remove that pipe to check it be aware that the reservoir will empty unless you pinch the pipe further up the line.
                      91 S2 coupé - RIP
                      • shaun5
                        • 1610
                        might be a loose clip at the resevoir end and a slight amount is coming down the pipe.
                        • Colesy
                          • Feb 2009
                          • 2980
                          Cheers for all the replies, just the info I was after, I'll probably just get some new hose.
                          • S2TORNADO
                            • Jan 2008
                            • 620
                            you might find its more than just a piece of hose. the fittings alone are quite expensive.
                            audi charge a fair bit for it and when i went to get one made it wasn't cheap either.
                            • Christophski
                              • 3632
                              If its the one I think it is nla when I tried a few months ago and Peter reeve said he could get one but was around £250.... Getting one made is prob cheaper. I got lucky with a car being broken
