Hi, am taking my swaybars off the RS2, to have them powdercoated. While I'm at it, I thought about what options there are to change the swaybar rubbers/bushings to something "better"? Stiffer version? As that's the only thing I change, would it make any noticeable difference? Any input welcome!
thnx.
T.
IMHO one of the simplest, cheapest and most EFFECTIVE (& easily reversible) modifications for an RS2 is to stick a Neuspeed 19mm RARB on the car, on it's stiffest setting. It makes an immediate, positive improvement to the car's handling and makes it much more neutral overall. (removes most if not all of the cars tendency to under steer)
thanks for the info. Currently I run the RS2 suspension completely stock. What would be the first (noticeable) recommended upgrade? The mentioned rear swaybar? I'd like to upgrade the suspension step-by-step (guess the front bushings will need to be replaced someday as well + eventually the shocks). Car is not a daily driver, but needs to be somewhat comfortable, not too sporty. Looking for more precise handling.
