pictures wanted of stock S2 suspension setup
  • archiboy24
    • Sep 2003
    • 286
    i'm looking for pictures of S2's with stock suspension setups. the reason is, i have a set of S2 springs (3B) that i am going to install on my S2 conversion project and i'm just wondering how much lower the car will sit. right now it has the stock springs that came on the '91 7A powered coupe.
    thanks!
    Ben
    Calgary, Alberta
    Canada
    1991 CQ e//S2 w/ RS2 spec 3B 20vt
    Panther Black Metallic
    www.moda-architecture.ca
  • Martynf
    • 1885
    Losely speaking... here are the rough details:
    A 3B without aircon, the springs are 300mm long
    A 3B with aircon, they are 310mm long
    The 7A without air con is 320mm long
    The 7A with aircon is 340mm long
    The poundage of the springs obviously comes into play with the air con springs being stronger as also does how old the 3B springs you have are, ie how much static sag they have from the use they've had, but I reckon you can bank on 20mm being the rough drop to expect with the 3B springs.
    What a long winded way to say 20mm
    Martyn
    Martyn
    www.vagparts.com
    • archiboy24
      • Sep 2003
      • 286
      thanks martyn, that helps a bunch. i was hoping it would be in the 20mm range! by the way, where did you get this information? also, is this info for the front, back, or both?
      Ben
      Calgary, Alberta
      Canada
      • Martynf
        • 1885
        I only checked the front springs, if you'd like I'd check the rears but I expect it to be pretty much the same story. I have this info 'lying' about!! it's amazing what you collect!
        Martyn
        Martyn
        www.vagparts.com
