Decent quality CV joints
  • philj
    • Feb 2010
    • 377
    Euro car parts were trying to fob of some happy clapping panda CV's on me, GSF have some GKN which after a bit of research it seems quality can vary despite being OE. Can anyone recommend a brand that's done some hard miles on their s2?
  • Thuppu
    • 4115
    GKN seems to use Löbro CV joints. Löbro is a good quality brand, the joits it self is good, but have heard the the rubber boots isn't so good anymore. OE rubber boots are a lot better.
      Lobro are the OE ones, Lobro is a GKN brand - they are as close to OE as you will get i think, although everything these days is built to a tighter budget than 20 years ago
      • terrybullwon
        • Mar 2006
        • 8782
        As Alex said
        Audi sport used Lubro which is GKN
        Other good brands are
        PEX
        Martelli
        Chef
        • quattro84
          • Mar 2006
          • 947
          What make of boots do you have now James? Looks like a more silicone based version.
          I asked CDX in Sweden for some motorsport CV's but never got a clear answer (yet)
          • terrybullwon
            • Mar 2006
            • 8782
            Racing Lubro ones with plastic O-rings to stop the boot from crushing and pushing all the grease out. Same as the works cars
            Chef
            • philj
              • Feb 2010
              • 377
              Cheers for the info.
              If anyone is after one GSF Kingston have a GKN S2 outer cv joint there for £22, last one before they go over to the Chinese GSP stock.
              • John B
                • Apr 2008
                • 926
                CV joints
                Don't forget the UV joint may need a fettle if your CV's are goosed and the prop shaft may need balancing to remove any vibration.
                GKN and their companies are the OE ones available now as discussed above.
                JB
                2001 996 C4 - Being renovated
                1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
