And now....something completly different!
  • psiconauta911
    • Oct 2007
    • 613
    • Country: Portugal
    Have anyone considered and is it possible using the hydraulic system on our S2 as a base for a kind of Citroen suspension conversion transforming an S2 into a lowrider/allroad?
    Its probably possible, but I probably wouldnt want to attempt it though
    • djh
      • Jun 2011
      • 1622
      There is already pics of a coupe on air suspension on this site if you look.
      • psiconauta911
        • Oct 2007
        • 613
        • Country: Portugal
        I mean, my avant is taller than ideal for really good handling on OEM suspension but it´s to low and keeps touching the ground on some silent policemen or exiting some garages and of course for some light off road, if a Citroen kind of hydraulic suspension from a Xantia or XM(or some other model like the activa one) could be adapted to our existing hydraulic system in a way that the normal height would be kept but you could lower it to the lower setting for optimun road holding or highways and lift it for when you have to do some light offroad or exiting some steep garage ramps!
        Is this doable? The car already has a pressure acumulator and an hydraulic pump, is this a case of apllying the citroen spheres and dampers and do some kind of hydraulic conection between both systems and installing the elctric comand for the height adjustment.
