Changing inserts
  • bilko0795
    • Feb 2011
    • 1883
    Changing inserts
    I'm trying to get the old inserts out of the struts and they won't budge is there a way of getting them out ie special tool.
    Thanks
    Have you managed to get the caps off mate? If so the just pull out
    • andy10v
      • 5996
      VAG2069A is the cap tool. (long tube with a hex end that fits inside the cap hex)
      Most people just use stillsons.
      You may well need to use stillsons to wind the shock out the housing, twist and pull at the same time.
      Sold ABY-stock
      • andyg plym
        • Nov 2006
        • 4646
        stilsons all the way and if needs be a bit of heat
        • bilko0795
          • Feb 2011
          • 1883
          Tried heat and some giant stilsons no joy
          • chezz
            • Apr 2007
            • 440
            Large metal working vice/heat/hammer...generally, the caps will be damaged/scored by this method.
            • mcandmar
              • Apr 2004
              • 5118
              Vice and stilsons with a long metal pipe on the end, if there really stubborn add heat but it will cook the seal on the shock so only advisable if the shocks are being replaced. I have split a bench vice clean in two trying to undo a strut before. I have seen mention on the forum of somebody substituting a street drain instead of a vice to hold it
              Either way it will come off, no matter how rusty it looks the threads will probably be perfect once you break it loose.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • K Simmonds
                • Dec 2007
                • 7627
                If your still stuck with Stilsons and heat, using a mini grinder and 1mm disc carefully cut four evenly spaced slits up the side of the top cap that only just make the thread. It will come undone easily then, obviously you'll need new top caps..
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                • driftin jo
                  • Sep 2007
                  • 2222
                  I agree, although in my experience 1 slit is enough,
                  you can just use a hack saw if you done have a 1mm
                  cutting disc.
                  Slitting it releases the crushing pressure on the thread
                  due to rust, this is why they are so hard to undo when they
                  are old.
                  • chezz
                    • Apr 2007
                    • 440
                    I probably have not explained my need for the vice clearly...I inverted the strut and placed the offending cap into the jaws of the vice and tightened it up using a little assistance from the hammer to gain a little extra pressure and then tapped the strut arm to undo the cap.I hope this provides a possible alternative method.
                    • bilko0795
                      • Feb 2011
                      • 1883
                      Have tried chezzs method no joy time for the disc method can you still get the top caps?
                      • shaun5
                        • 1610
                        You could try leaving the caps in a bucket of diesel for 24 hours and see if that helps. Also use the vice as a hard base and give it a tap with a hammer.
                          Yes you can, they are not cheap though IIRC about £12 each
                          • spink
                            • 4382
                            you quite often get new ones with shockers.before you put the new shocks into the struts tip a little oil in,apparently it helps get rid of heat from the shock.should also prevent it seizing in the strut which isnt fun when that happens.btdt
                            • rj scotty
                              • May 2006
                              • 2195
                              did you do what I did and drill a hole in the bottom of the strut/drift big hammer/weld up?
                              That was after struggling for half a day trying just about everything else
                              BUT I DON'T WANT A NEW CAR!
                              1995 S2 Avant, Volcano Black
