RS2 Track control Arm identification
  • wowow
    • 123
    • Country: Hong Kong
    I have a RHD RS2 and needs to replace the bushings on the track control arm. In the VAG diagram, it shows 2 arms and by visual check , my current one should be the lower arm - 1a (893407148D). Are the bushings on either side of the arm the same and replaceable, ie part number 2a (893407181) ? Or do I have to buy the complete arm because bushing on the other side of the "Y tip" is not replaceable.
    ________________
    RS2-95
  • wowow
    • 123
    Also, I need lower ball joints as well ( shown as "guide joint" ) in the diagram. But he parts list shows 1 part with "3" and 3 parts with "(3)". Should I be getting 895407365A ( L ) and 895407366A (R) to match the "1a" arm ? This is quite confusing. I wish they label is "3" and "3a", "2" and "2a".
    ________________
    RS2-95
    • mcandmar
      • Apr 2004
      • 5118
      Bushings are the same each side, so you need two of item 2a per arm. Ball joints are handed so you have a left and right hand side version, and they are also different on the cast arms vs stamped steel. From memory the part numbers with the A on the end are for the cast arms, i.e. the 365A 366A ones.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • wowow
        • 123
        many thanks. that helps.
        ________________
        RS2-95
