Can it be a steering rack problem?
Suspension problem?
History:
Pro mounts,
bilstein shocks and stock springs,
oem steering rack.
Single vane steering pump 100bar,
oem drop links,
oem subrlframe bushes and poly suspension bushes.
Recent non oem tie rods with oem rod ends. Bracket that holds the tie rods has the bolts loose so will be changed,
Also a random knock when the steering wheel is turned from side to side, sometimes close to the straight ahead area, sometimes elsewhere.
Your thoughts?
sent with Nokia 6210
Suspension problem?
History:
Pro mounts,
oem steering rack.
oem drop links,
Your thoughts?
that also causes the clunk near the straight ahead position
