More caster
  • 5cylinderman
    • Oct 2011
    • 367
    More caster
    After noticing that this chap listed fitting cabbie ball joints to give more caster on this thread:
    A little background before I go in to discusion about some mods I am about to under go a big suspension and brake upgrade on my 88 90q. Its been needing alot of this stuff for awhile now and im planning on doing it all in one shot on a lift at work. I have been compliling new parts and re...
    Halfway down the page I see that he shows a difference between the front lower ball joints fitted to B3 20V Saloon and B4 cabbie. It this information correct? I'm looking into methods to lessen understeer in my S2 coupe.
    I think you will find you already have the later type ball joint on your car
    Quick and cheap mod to reduce understeer is a stiffer rear ARB
    • jade
      • Jan 2005
      • 1811
      What has transformed my RS2 is running 245 on the front and 225 on the back it has great turn in now and feels more balanced
      RS 2 580HP
        What profile on the 225, and also the 245 ?
        17" or 18" ?
        Thanks.
        • jade
          • Jan 2005
          • 1811
          17" or 18" ?
          Thanks.
          245/40/17 and 225/45/17 rear
          RS 2 580HP
          • Takumi
            • Oct 2009
            • 120
            • Home: Lithuania Current: United States
            can someone explain, how come because of narrower rear tyres it turns in better? Back begins to slide? I understand, that maybe wider front has more grip, but how about rear - where is the key?
            BLOG: http://quattro10vt.wordpress.com/
