Incorrect Ackermann: Why does my outside wheel scuff wide on full lock?
    yeah it'd probably work as a door stop
    Here you go, they are used on leaf springs.. not much good to any vehicle that has suspension designed after the 1st world war.
    http://www.superiorengineering.com.a...oducts_id=1682
    • stocious
      • Jul 2012
      • 838
      ahhh the horror!! lol . i thought id heard and seen the last of leaf springs lol. my fingers are sore at the thought. darn HINO'S, pure torture
      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
      • A1QSHIP
        • Aug 2004
        • 975
        Those are for shimming a solid axle & leaf spring assembly to get proper driveshaft to universal joint angle. There is no place on any modern audi where these will be useful.
        Here is a better description. http://www.ingallseng.com/leaf-spring-wedges/
        They do have parts for VAG cars though.
        Here is something to consider when changing suspension angles. Lower ball joint extenders. http://www.pmwltd.com/index.php. Helps to correct camber change during suspension travel with a lowered vehicle.
        "Nulla tenaci invia est via"
        • afterburner
          • Mar 2012
          • 246
          • Country: Bulgaria
          I have shortened steering arms on my 80 Competition for more and faster steering... you should see what this does on full lock Don't worry, it's normal with our ackermann angle...
