Guys anyone had experience with kw coilovers on urs6's?
  • AUDIDOIT
    • Mar 2008
    • 30
    • Home: France Current: United Kingdom
    Seen that kw do a basic coilover kit on our c4 chassis s6's, just wondered how they compared to Koni/ eibach or H&R spring shock setups?
    And is there a company who do poly bush kits for the 1995 s6?
    Damien.
  • Gavin A
    • Nov 2012
    • 260
    Every set of KW i have owned, one has burst, the konis in my 944 have outlasted 3 sets of KW.
    • rs200
      • May 2009
      • 1398
      • Home: Croatia
      kw is biggest **** I ever see.
      I had it on my 200 20v, and first few month everything was fine , than spring became to be softer and softer every month, until now when it hit them from car and put old Eibach back on car. it was not possible to drive , even the smallest crack or bumper at the road will kick like I tought that will destroy front of car.
      KW V1 is garbage . waste of time and money.
      H&R or Eibach in combination with Bilstein (monotube) is best option for that car.
      • popdemonic
        • Dec 2007
        • 1304
        • Country: Thailand
        Damien,
        I found many cars has KW V2 and V3.KW shock abs is not last.one TTS has KW for 4months and shock abs blown out.
        one of a few I5 from Asia.
          Jeepers, was seriously considering a set of KW3s for my S2 Avant, as I wanted it lower using coilovers, (but not stiffer shocks or springs tbh).
          Do any other companies do coilovers for a B4 S2 Avant, or a C4 urS6 Saloon ?
          Thanks for any feedback.
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            That's worrying to hear, my S2 has a set of KW V1s fitted by the previous owner (back in 09). Glad they are still there, hopefully this thread won't jinx me
            1996 S2 ABY Silver
            • rs200
              • May 2009
              • 1398
              • Home: Croatia
              DIY is best option. I done it few times and everything is fine . perfect handling , low and soft enough !
              good luck !
              • philj
                • Feb 2010
                • 377
                The v1's are their budget range to be fair, kw are known to put in more R&D with their coilovers. They usually ride pretty well although I can't comment on longevity never got the impression it was an issue with KWs.
                • Yaz
                  • May 2007
                  • 445
                  Well that's interesting, as most or a lot of you know I'm a KW dealer and also run the group buy on here for KW V1's and V3's. Never had any issues with KW products. Their range does come with 2 years warranty anyway and like with most things, you're bound to get an odd one that fails from time to time...
                  Personally I would buy KW over any of the equivalent brands out there for the money, just wish I had the money to buy a set!
                  And i'm not just saying that because i'm a KW dealer as I deal many other brands also.
                  1992 Audi 100 2.8 Quattro
                  1993 Audi Cab 2.3
                  1995 Audi URS6 Avant
                  1999 Audi S8 D2 FL
                  2005 Skoda Octavia Elegance Variant TDi
                  2012 VW CC BlueMotion Tech DSG
                  • merlin's S4
                    • Jan 2005
                    • 1539
                    I noticed a thread on here where Bambridge (resident machine shop and fabricating specialist) has made a coil over set for the S2. Might be worth sending him a message about fabricating a setup for your S6.
                    I'm quite happy with my setup which is Bilstein shocks with Eibach springs. It's not the most forgiving ride but the S4 definitely feels very well planted and is much more direct when you turn in. I believe Koni shocks may be a little softer so a bit more of a performance/comfort compromise. I guess it depends on the usage and personal preferences.
                    Regarding poly bushes, I've only seen the rear subframe and diff bushes from Apikol. Bambridge has made delrin subframe bushes for the urS and they make a real difference, especially as OEM rear subframe bushes are NLA.
