I'm looking to separate the upper and lower ball joints on the car without damaging them as they are relatively new. Is it possible to do this and if so can anyone recommend a decent splitter for the task?
In the past, I used a cheap jaw style separator from Clarke but it snapped on me and had to resort to using a fork which inevitably damaged the the rubber bush on the ball-joint.
I would also be interested to know what tool you guys recommend to fit the clamp rings supplied with a new CV boot kit. Would the long handle plier type tool be sufficient enough to do a proper job or do I need the type which has 3/8" drive to supply the addition torque to close the seal as tight as possible?
Thanks for any pointers and links to your tools of choice.
Cheers,
Rob.
Cheers,
Rob.
