Hi sorry for the silly question but are the s2 bilsteins oil or gas?
because when I`ve removed the cap the bottoms full of oil if so is the oil stored in the outer casing with the bilstein insert sitting in the oil with the seal on the top inside the cap
my rods a undamaged but the seal is shot so rather than spend $£$ I could replace the cap for £15 and relace the oil
the inserts i fitted to my old 80 years back held their own oil
) when replacing strut inserts I was told to put a squirt of gear oil into the strut housing/casing before fitting the insert.....can't remember the reason for this but I've done it ever since.
