URS6 Front Bushes. Audi or Pollybush?
  • HMS-S6
    • Jan 2010
    • 1164
    As title suggests, my S6 wants front bushes AGAIN and i'm debating to put genuine Audi bushes in or pollybush it due to them not lasting long.
    My M3 is Pollybushed all round and feels fine but its a very different kind of use! The S6 is nt just a toy and is used for allsorts! Has anyone got one on polly? Are they too stiff or do they feel ok?
  • Liam Gallagher
    • Nov 2003
    • 52
    • Home: Canada Current: Scotland
    which bushes?
    Audi B3/B4 Photography group
    • HMS-S6
      • Jan 2010
      • 1164
      Originally posted by Liam Gallagher
      which bushes?
      Its basically all the front bushes except the top mounts!!
      • Rusty
        • 18953
        What do you use the car for? If it's only used on the road, then some decent quality rubber bushes will tighten things up without squeaking or giving additional noise or vibration in the cabin.
        • HMS-S6
          • Jan 2010
          • 1164
          Yeh to be honest, even if it sees a track, it won't ever be a 'track car', its used as a fast road car really
          • spink
            • 4382
            have you ever done the bushes where the front bottom arm bolt goes in thru the subframe rich?they sit into the floorpan.not many people seem to know they exist but well worth changing if never done b4.only aftermarket ones i know are made by 'thuppu' on here,totally solid tho so not sure how they are on a road car.
            • HMS-S6
              • Jan 2010
              • 1164
              No mate i've never done them ones! The S6+ wheels and wider tyres have showed up/finished off the old bushes now and its wondering way too much now!! What they like to get out?
              • spink
                • 4382
                either do them when subframe off or undo gearbox mounts and front subframe bolts and let the frame sit down at the back and you can just squeeze them in.they are held in by 3 bolts
                • spink
                  • 4382
                  • merlin's S4
                    • Jan 2005
                    • 1539
                    As Spink says, I am unaware of any poly bush kits available for the front of the C4 chassis so this will no doubt make the decision for you.
                    • Masterblaster
                      • Feb 2009
                      • 300
                      UrS4 with Comp CT4367,Vems and other goodies!!!! SOLD!
                      New project Audi S3 with GTX 28/67...
                      http://www.s2forum.com/forum/showthread.php?t=40308
                      • merlin's S4
                        • Jan 2005
                        • 1539
                        Originally posted by Masterblaster
                        As I said. Nothing for the front other than the snub mount (which I have).
                        • spink
                          • 4382
                          Merlin,have you got a list of all what bambridge makes for the c4q?I messaged him but havnt had a reply as of yet
                          • merlin's S4
                            • Jan 2005
                            • 1539
                            I only know of the rear subframe bushes which I believe he can do in Delrin or Aluminium. I have the original prototype Delrin versions and I'm very pleased with them.
                            I wonder whether Bambridge would be interested in developing some other C4 chassis parts? Although I guess it will depend on demand.
                            • spink
                              • 4382
                              i wonder if the outer bush on the rear tie rods would be doable.seems daft to replace them when the ball joint rarely fails,and oem are 130 each apparently
