I put in an order yesterday of a bit of a rear suspension refresh and everything was available except the rear hub>strut bolts that they said were 'discontinued without replacement in 2007'
Mine are the early M12 type and the part number I supplied them matched the number they thought it was - N 10206501.
They're nothing special, just need the same spec and roughly the same length bolt with 2 washers and a nylock per bolt. Will cost about £1 for the lot at a local fasteners supplier
