Top mount - tip
  • mcandmar
    • Apr 2004
    • 5118
    I'm surprised that made any difference, surely the shock's themselves would rotate and flex under load causing more alignment change long before the top mounts did anything
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • DJones
      • Jun 2005
      • 2020
      Top mounts are a week point in the chassis of Ur's and S2's. Proof is in the pudding... nothing else made a difference. As Rusty said the more power you put through it the more you find the weakness..
      • mcandmar
        • Apr 2004
        • 5118
        oh believe me i know they are a weak point, i just never envisaged the rotation at the rear being an issue. With the silly power your putting out you should also look into forward link bars for the a-arms as per the sport quattros, you must eat a-arm bushing in that car.
        • speeding-g60
          • Aug 2008
          • 1186
          FWIW, MK1-2-3 VW's have no bearing at the rear? its just bushings sandwiching the body portion of the mount, the cup or whatever you want to call it.
          they have FWD and are just a shock in the back.
          i think Audi may have done it for simplicity, so as to not confuse people and just make one part fit both ends.... no difference front to rear. one part fits all.
          • DJones
            • Jun 2005
            • 2020
            Yes thought of that, its on powerflex so no issues yet..
            • GazzaG60
              • 4133
              I used promounts front and rear on my s2. no such issues with good mounts. what I found is the bearing was seized when I took them out of the rear. obviously no movement there.
              I reckon the shock following the bushes etc would move first.
              • URquattroGus
                • Aug 2007
                • 547
                Darren
                This seems like a good idea, I'm thinking of giving it a go. I have a bit of loose back end too
                Stupid question, how do I get to the rear top mounts? Never had to touch the rears (I got someone to replace them)
                Can I just undo them at the top and let the strutt drop down?
                Angus
                Angus
                (1984 ur quattro)
                  If its a coupe you need to remove the plastic covers either side of parcel shelf and tucked behind the boot carpet
                  • Laaf
                    • Oct 2010
                    • 275
                    Is it supposed to be any movement in these when the nut is tightened down and the springs isn't compressed? I can wiggle mine on one side a little bit, but I haven't gotten the other side out yet to check if the other one is doing the same.
                    • PaulJ
                      • Jun 2008
                      • 253
                      Rear steer on an RS2
                      Hi Folks
                      Had a very similar problem on an RS2, Changed all bushes for new Audi set, Re-aligned, new dampers / springs, issue still there, checked out subframe bushes, everything looked OK, by now getting totally fed up with it, Changed for powerflex, still no difference, Anyway removed subframe for sandblast powder coat and installed a set of bambridge solid subframe mounts, problem solved, was the issue all along, originals looked perfect even off the car, would not like to try to fit new set of rubber bushes into that subframe, suspension is hard as hell and chase squeaks continually but ho hum, Think solid subframe and rubber everywhere else would be a good balance
                      Cheers all, thanks for a great forum
                      1995 RS2 Nogaro
                      1971 Lotus Elan Sprint
                      1974 Lotus Elan+2S 130/5
                      • DJones
                        • Jun 2005
                        • 2020
                        Originally posted by URquattroGus
                        Darren
                        Angus
                        Hi Angus
                        The rears are little fiddly.. You need to remove the rear seat back and pull out the parcel shelf, the top strut nut is normally covered by a lump of foam.
                        Undoing them will indeed allow the struts to drop but only as far as the drive shafts will allow before they bind on the sub frame, which is not enough to get them out.
                        Whilst it sound heavy i pulled off all the vacuum lines to the rear diff, undone the prop-shaft, undone all the sub frame bolts, removed the rear calipers and just dropped the rest straight out of the bottom and hey presto everything is easy to get at..
                        Hope it helps...
                        Darren.
                        • URquattroGus
                          • Aug 2007
                          • 547
                          Originally posted by DJones
                          Hi Angus
                          The rears are little fiddly.. You need to remove the rear seat back and pull out the parcel shelf, th to strut nut is normally covered by a lump of foam.
                          Hope it helps...
                          Darren.
                          Thanks, a bit more work than meets the eye then, thing is, I don't have a ramp! There is one at work, but not easy to leave it in bits....
                          I'Ve been thinking about converting the strutts to height adjustable coilovers with weld on collars, so probably ought to do it all in one go!
                          If only I had enough height for a ramp that and a better heater!
                          Angus
                          (1984 ur quattro)
