DIY wheel alignment
  • Pat D
    • Dec 2011
    • 748
    • Country: Australia
    Originally posted by Sir Buff
    This looks quite good and its cheap enough as well. Cheers for the link
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
    • G60Rallye
      • Dec 2006
      • 1321
      Good enough for the top level of motorsport!
      • AndyP
        • 6049
        Originally posted by terrybullwon
        Built this for mine.
        I still need a good days work to get it 100% but you get the idea
        That looks similar to the set up that Evert used on his racecar
        I think short term I'm going to pay to get it done, in the mean time I'll try and make something like this and I'll take some measurements off the car when I know it's set right, then I'll know what to set it back to.
          Stringing it up is all well and good but the main issue as I see it is adjusting it all - you need to support the car on its wheels high enough to get under it to access the adjusters. Plus you need to be able to roll it back and forth slightly after adjusting it, to settle it all down, before you check the measurements again. Maybe I have missed something but it seems next to impossible to do at home unless you have a pit?
          • terrybullwon
            • Mar 2006
            • 8782
            Or your car is on uni balls and no standard parts left
            I brought some treated marine ply to go under the wheels to lift the car aprox 100mm off the floor
            Chef
              So you still need a skinny midget to do the adjustments for you then mate?
