Boge fronts are avaiable from the stealers but not from boge themselves but are pricey, the rears are still available from boge £80 a pop as i bought a set. Yaz on here does the B6s in his group buy thread good price to.
I've had both and the Bilsteins are much stiffer than the Boge. You can run the Boge with std springs but I would recommend uprated springs with the Bilsteins.
Got my Bilsteins from Yaz at a great price
I'm sure I've read that the Bilsteins are 30% stiffer than std so you need springs to match. I've gone for 250lb springs on my coil overs ( 25% higher than std ) and they seem to be a good match.
Depends on your likes for driving..and yeah, how you can put up with our third world cart tracks that masquerade as roads..The latter is why i went for softer suspension than i normally prefer..so all new standard springs, standard fronts (from stealer 3 yrs ago)and cos I was ordering other stuff from QST at the time,and they had almost new rear Konis off a customer's car,I stuck 'em in. It's not a bad setup actually, and I run standard wheels too. But I do get up some really rough roads at times, so granted it's a compromise
That is spot on but if you don't have coil overs can we get uprated (stiffer) springs (except h&r's)?
and that is why I went to coil overs!!
The only option ( AFAIK ) is H&R's and they are not made any more, the spring choice for coil overs is virtually unlimited and they are reasonably price at around £40ea.
Hi Mike, I have just sent you a PM with prices, sorry for the late reply... been away this week.
Also thanks to all that have recommended me
Yaz
1992 Audi 100 2.8 Quattro
1993 Audi Cab 2.3
1995 Audi URS6 Avant
1999 Audi S8 D2 FL
2005 Skoda Octavia Elegance Variant TDi
2012 VW CC BlueMotion Tech DSG
I installed Boges for a friend's aby coupe. After driving with it, I'd say they are far to soft. I'd choose bilsteins even with oe-springs. I don't see a downside having a little soft spring vs. shock. Vice versa it's a catastrophy considering the handling.
Agreed, after all the B6 Sport dampers are designed to work with factory springs.
1993 Audi Cab 2.3
1999 Audi S8 D2 FL
I agree too, i have all std springs and Bilstein B6 with Avus 16". I like this setup very much, no fear of sudden bumbs and holes
'93 Audi S2 Avant panthero black, 412.000km
'94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
'93 Audi S4 C4 Avant, 260Tkm
'88 Audi 100 Avant turbo 44Q
'84 Audi 80 quattro tornado red
