Front and rear arb setup
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    What setup would be optimal front and rear? Is rs2 farb 28mm and whiteline rarb 18mm a good setup? Let me know what you guys recommend
    1996 S2 ABY Silver
  • Colesy
    • Feb 2009
    • 2980
    ^^ I have this setup and love it.
    Whiteline with stock FARB was good also.
    RS2 FARB without a whileline or equivalent RARB would be a very bad idea.
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      That's settled then
      I've found an RS2 FARB on here, where should I get the whiteline RARB from?
      Also, is there anything that needs doing when installing them? My mechanics are fairly capable so it shouldn't be a problem I think, but we don't like surprises
      1996 S2 ABY Silver
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        Are these drop-links suitable for RS2 farb? Can anyone guide me with what else I may need please (brackets and such)
        This website is for sale! germanautopartsdirect.co.uk is your first and best source for information about germanautopartsdirect. Here you will also find topics relating to issues of general interest. We hope you find what you are looking for!
        Also would the whiteline rarb need anything extra besides the bar? Cheers
        1996 S2 ABY Silver
        • Christophski
          • 3632
          I'm not a coupe person so I don't know bud but when you do them get them poly bushed too. My car has rs2 f and r bars and I want to poly bush the whole lot next to help a bit more
          • Colesy
            • Feb 2009
            • 2980
            A new whiteline rear comes with a fitting kit which includes bushes and brackets, you just need longer bolts and could replace the drop links but isn't essential.
            The RS2 front will need RS2 bushes to fit, I can't remember if the brackets are the same so would check and new RS2 or ABY drop links would be an idea but again not essential.
            • TimE-J
              • Jul 2009
              • 1292
              According to ETKA the ARB bush clamps are the same for an RS2 and a coupe.
              96 S2 aby Coupe. Rebuild Project
              96 mk3 golf tdi daily.
              • rynaqui
                • Mar 2012
                • 2752
                • Country: Malta
                Can anyone guide me on the front? As I don't know what this all means
                Thanks for the help everyone!
                1996 S2 ABY Silver
                  You need to buy some 28mm Superflex mounts:
                  Item SF080-2659K in 28mm
                  HTH
                  • rynaqui
                    • Mar 2012
                    • 2752
                    • Country: Malta
                    So is that all that's needed then?
                    I appreciate it Alex!
                    Is replacing the drop links optional?
                    Cheers everyone
                    1996 S2 ABY Silver
                    • lcsmith
                      • Jul 2007
                      • 477
                      Hi Guys,
                      Maybe a touch off topic but does anyone know if this set-up can bolt onto B3 90Q 20v subframes?
                      Audi A4 (B7) 2.0 Tdi (140PS)
                      Audi 80 (Typ 89) Quattro 16v
                      2 x Audi URS4 2.2 20v Turbo
                      Audi 100 (C3) Quattro 2.2 10v Turbo
                      Audi 100 (C3) 2.2 10v Turbo (Auto)
                      Audi 200 (C3) 2.1 10v Turbo - Scrapped
                      2 x Audi 80 (Typ 89) Quattro 1.8 8v - Scrapped
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        Not sure myself but no worries about off topic
                        I'm planning on getting RS2 front and rear drop links while I'm at it, might as well do it all right..
                        1996 S2 ABY Silver
                        • Colesy
                          • Feb 2009
                          • 2980
                          I'm not sure but you probably don't want RS2 rear drop links on a coupe. I'd stick with coupe rear drop links.
                          • caterpillar
                            • 2480
                            front an rear parts
                            Originally posted by lcsmith
                            Hi Guys,
                            all the small chassi areall the same... from vw passat in 1975-76, and audi 80/90/s2/rs2... minor detal suffer.. like teh wishbone and drivetrain... so if you car are a r5 or v6 verson, the mostli parts will go in....the 4 pot verson( petrol) does hav the engine mount on the subframe, but some diesel verson( 89-) doesnt, so then the front and rear arb's goes in....
                            for the vw 32b syncro cars; use the thicker rear arb for paasat 35i (20 or 25mm) or the rear arb from vw golf syncro (18,5mm)
                            in front from audi 90 gt (26mm) or 20v... or from rs2 (28mm)
                            • rynaqui
                              • Mar 2012
                              • 2752
                              • Country: Malta
                              Is there a particular reason why? Too stiff? Is it safe to keep the S2 drop links if they are a bit on the old side with the whiteline rarb? I'm guessing they've never been replaced..
                              So far have ordered the 28mm superflex mounts for upfront, front RS2 drop links, am still deciding on where to purchase, possibly from quattro corner if Pete has available. RS2 FARB I'm getting from someone on the forum
                              1996 S2 ABY Silver
