B3/S2 springs.
  • John.
    • 2615
    B3/S2 springs.
    Have got a B3 Coupe quattro and I'm wondering if the suspension springs from an S2 will fit straight on...... the car's on standard springs and shockies at the moment but thinking about lowering a tiny bit.
    I'm not over keen on getting lowered/uprated springs as it might end up too low and too hard so thought standard S2 springs might do the job ??
    John.
  • Rusty
    • 18953
    You want the 1BE option sports springs. S2 springs are a version of that but I'll need to check the family album to see how many variants there are. They will physically fit though and I'd get 2x rear pairs, then you'll get a nice stance too, as the rears are about 20mm shorter. Match to Bilstein or Koni dampers for a firm and sporty ride, stock sports dampers for a bit more compliance. Also upgrade your rear roll bar.
      The S2 upper spring perch is slightly bigger than the coupe quattro ones, but S2 springs will still fit
      • Mikes2
        • 1704
        S2 springs are a straight fit
        Mike
        http://www.s2-audi.co.uk
        • John.
          • 2615
          ok, thanks chaps.
          John.
