Coilovers C4 S6 V8 saloon...
  • smiler
    • Nov 2008
    • 435
    Any one make for the V8 saloon?
    Just H&R lowering springs are very expensive.
    Had Eibach/bilstein kit on my previous plus but it didnt lower it enough.
    Thanks!
    /Thomas
    RS2-94
  • Thuppu
    • 4115
    K&W and FK make ones for C4.
    • Mr30psi
      • Jul 2013
      • 45
      On this note has anyone else besides EDIGREG made the strut conversion to the coilover?
      Such as
      Ive been dying to get some for my urs4
      -kavon(Mr30psi)
      • smiler
        • Nov 2008
        • 435
        For the 4.2l plus saloon?
        Emailed several without response yet.
        /Thomas
        RS2-94
        • Thuppu
          • 4115
          KW makes a Variante 1 kit for the C4 chassis: http://www.kwsuspensions.com/produkt...terGroupID=1-1
          You have to send them the struts and they make the coilovers out of them. They are not stainless, only zink coated.
          • smiler
            • Nov 2008
            • 435
            Im blind... S6 limo just 4B not C.
            /Thomas
            RS2-94
            • Thuppu
              • 4115
              Seems that my link isn't working anymore. Look under S4 C4.
              • rs200
                • May 2009
                • 1398
                • Home: Croatia
                I did home made coilover for my 200 20v with KW V1 spring (AUDI D11) and bilstein shock absorber.
                it is low and all ok , but it is not some performance car than !
                • smiler
                  • Nov 2008
                  • 435
                  Ok same for S4 and S6 then?
                  Found these if they fit...
                  /Thomas
                  RS2-94
                  • rs200
                    • May 2009
                    • 1398
                    • Home: Croatia
                    it is all the same for audi 100 (c2,c3,c4) 200 (c2,c3) , V8 (D11) , S4, S6 (C4).
                    but all spring from this coilovers is too soft .. it is my opinion, and my choice will always be DIY !
                    you will probably buy this :
                    • smiler
                      • Nov 2008
                      • 435
                      Hmm ok thanks...
                      So you could build a set for me?
                      I will use the car only in the winter as my "daily" driver.
                      /Thomas
                      RS2-94
