Hi All,
I recently replaced the main hydraulic pipe from the pump to the Steering Rack (the one with the steel 360deg loop, which had a pinhole in it).
Ever since, when 'loading' the steering wheel with engine running, there is a strange howling that can be heard inside with the windows closed, and it can be felt through the wheel.
The pipe that I fitted was made locally for me, a stainless braided unit which does not incorporate the loop. The only other difference is the solid block on the OE pipe where it fits into the wire support bracket under the water manifold (I don't suppose that is some form of pressure regulator/damper?)
Any suggestions??
Any suggestions??
