Strut paint
  • chezz
    • Apr 2007
    • 440
    Strut paint
    Can anyone recommend a decent paint for struts? I have converted over to Compbrake coil overs and they are ready for another lick of paint, as the Carplan engine lacquer flakes/chips all too easily, worse than Hammerite - if that is possible!
    Powdercoating has crossed my mind as an option.
    If you can find somewhere to do it I would get the tubes cad plated, then paint over with 2K. Its probably the only thing that will ever stop them rusting
    • Rikki Kitto
      • Feb 2010
      • 6276
      I used hammerite on mine, bright yellow
      • gripper
        • Jun 2008
        • 1156
        Same here
        Done mine almost 2 years ago now and they still look good !
        For what this cost me so far I could have bought an S2
        • martinws
          • Oct 2008
          • 917
          I've got 2k on my struts and por15 on most other parts. The problem with hammer***** is that water gets under it and rusts it out and all looks fine on the outside. I've had this with a few parts.
          • Rikki Kitto
            • Feb 2010
            • 6276
            What about powder coating?
            • chezz
              • Apr 2007
              • 440
              How tough is Powder coating...does it flake and chip easily?
              • Rikki Kitto
                • Feb 2010
                • 6276
                My subframe is powder coated and seems to be doing just fine after 2 years
                • varia
                  • 821
                  • Current: United States
                  in the US, por15 is very popular (por15.com)
                  • audinut
                    • Jul 2009
                    • 2195
                    powder coating is the only way ! :-) IMO
                    NOT a car dealer! just an S2/RS2 enthusiast
                    • bikerjim
                      • Feb 2008
                      • 1028
                      I used some rubberised paint from halfrauds on mine and the still look pretty good - http://www.halfords.com/webapp/wcs/s...egoryId_165495
                      • bikerjim
                        • Feb 2008
                        • 1028
                        But i do agree, powder coating is a better solution!
                        • martinws
                          • Oct 2008
                          • 917
                          I galvanised and then por15ed my subframes and wishbones. I dunno how powder coating would go with the threads on coil covers though.
                          • chezz
                            • Apr 2007
                            • 440
                            Por15 is extremely expensive - per volume. I will investigate the powdercoating option, as there is a wheel refurb workshop, close to work. Plating and 2K sounds like a good solution also...Id rather use kids poster paint before Hammerite though lads
