Power steering fluid?
  • Rikki Kitto
    • Feb 2010
    • 6276
    I know it's a stupid quetion and I should know by now, which one is it? green? but are there various green ones or are they all the same?
    G004000
    • europeanme
      • Oct 2005
      • 3817
      green....get it from TPS....
      • Rikki Kitto
        • Feb 2010
        • 6276
        Bit worrying, mine looks clear like brake fluid
        • Laaf
          • Oct 2010
          • 275
          Audis green gold is the way to go.
          • Rusty
            • 18953
            It's FEBI 6161 or 6162 from GSF / ECP, depending on whether you want synthetic or mineral.
            • Thecrispynoodle
              • Jul 2012
              • 269
              Redline, Opie oils sell it. Fantastic stuff, no need to flush it will mix with OEM.
                are you sure it is compatible?
                • Thecrispynoodle
                  • Jul 2012
                  • 269
                  Number of people on Quattroworld including me have mixed it with OEM fluid without issue.
                  • Mcstiff
                    • Oct 2004
                    • 504
                    G00 is not very complex and mixes well with Redline and M1 ATF.
                    1995 1PissedOff90sigpic1991 USDM CQ 7aT
                    • europeanme
                      • Oct 2005
                      • 3817
                      deleted
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        Originally posted by europeanme
                        deleted
                        ?, I've mixed it now so too late hope it's OK
                          I can mix anti-freeze with Ribena, but its not any good for me
                          The problem with some non-OE fluids is that they degrade the seals over time, so maybe it won't manifest a problem for some years.
                          IMHO why bother when the correct fluid is cheap and easy to get hold of, on the shelf at every Audi dealer in the country. Each to their own though, hope it works for you
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            True
                            • veneto rs2
                              • Jun 2006
                              • 1022
                              • Country: Veneto
                              Bible not simply true.
                              http://www.audisportclub.com/
                              http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
