On these damp mornings you'll hear a "doing" from your front springs when turning from lock to lock at low speeds, ie reversing out of your driveway etc
Only if the spring has been fitted upside down...
Thanks guys, no rattles or creaks to be heard, so they may well be okay. Is there any visual check or test I can do without resorting to removing them from the car? Would it be ennough to remove the limit stops on the strut towers and have a look at the condition of the mount bearing from there?
So whats the latest thinking on topmounts then, The ones on my RS2 are toast, fed up changing them but don't want to go too hard as HR coilovers fitted, What are the options, I'm assuming that the mountsavers are NLA
