80 B4 Rear suspension camber bolt stuck
  • vism
    • 97
    • Current: Norway
    Hi
    i'm having a problem trying to separate Control arm and rear hub, (See attached image from forum)
    cant seem to undo the eccentric bolt.. any tips or tricks for this one? Tried hitting it a few times With a large hammer, but no go..
    the suspension have been stored for some time and most of the bolts are pretty much stuck, managed to get out most of them but this one is quite a PITA..
    '91 Audi S2 Coupe
    '85 Audi 80
  • 80Quattro
    • Sep 2006
    • 420
    • Home: United Kingdom Current: New Zealand
    I rebuilt mine which appeared to have been untouched for 15 years and it took hours longer than it should have. An impact wrench is the answer, make sure you use it on the nut and hold the bolt still.
    92 Audi 80 Quattro => RS2 Saloon!
    98 TVR Cerbera 4.5
    63 Austin Mini Super Deluxe (turbocharged)
    69 Austin Mini Cooper
    71 MGB GT
    75 Daimler Vanden Plas 4.2L
    04 Kawasaki GPX250
    96 Subaru Legacy GT-B
    • caterpillar
      • 2480
      try; corium 127.... like the wd40, but it have some other skills in...; the when remont the parts, the wood tare(!!!) in spray from biltema or some paintshop
      • vism
        • 97
        • Current: Norway
        Got the nut loose from the bolt, but the bolt is still stuck within the bushing..so no special tricks to get this out, just push it out?
        '91 Audi S2 Coupe
        '85 Audi 80
        • rj scotty
          • May 2006
          • 2195
          I had to drill mine out, took best part of a day
          BUT I DON'T WANT A NEW CAR!
          1995 S2 Avant, Volcano Black
          • K Simmonds
            • Dec 2007
            • 7627
            I've had to deal with a few of these, if it won't free up the quickest way to get it apart is to cut the head of the bolt off as well as the other end with the nut as tight to the arm as you dare with a 1mm cutting disc. The control arm can then be released from the hub with a bit of leverage applied each side of the adjuster and the assembly separated, there's still the remains of the adjuster to remove but at least one can now get at it and burn it out etc.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • 80Quattro
              • Sep 2006
              • 420
              Drill one end of it so it has a dimple, then use an air chisel with a pointed bit. Has worked for me to get a bolt moving then you can hammer it out.
              98 TVR Cerbera 4.5
              71 MGB GT
              04 Kawasaki GPX250
              • K Simmonds
                • Dec 2007
                • 7627
                That can work with these bolts but not always, when I was working as a mechanic I'd try that technique first before moving on to more aggressive tactics. Not many folks have compressed air at home though, hence me suggesting the cutting method.
                The other real feker we used to have to deal with on regular basis was A4/Passat etc front upper arm pinch bolts, they can be a complete pig, seen a less experienced lad snap one clean off which causes a great deal of hassle.
                1994 MTM RS2.
                2000 B5 TQS.
                • pixsaudisex2
                  • Sep 2004
                  • 3110
                  I had one the other day on a a4.
                  Not the same but i cut the head of it then done the nut up as much as i could and it came lose undone the nut and knocked it out..
