I have the older version ( pre 2011 ) of KW V3 in my RS2. The car has not been running much and the bump stop cracked and hence I damaged the damping cartridge ( as they call it ) when going through big bumps ( damper bottomed and damaged the valve I guess ). I like to know :
1. if the damping cartridge is available as a spare part, or I have to buy a completely new set which includes the casing ? If so, any one has the part number ?
2. If they don't sell the old version anymore, would I have to replace both the front with the new V3 ? I heard that the new V3 is virtually the same as the old one except for a newly designed adjustment knob. Can I just buy one "new" V3 and have it work with the old V3 on the other side.
Thanks
Thanks
