rear track control arms
  • caterpillar
    • 2480
    jeah.... but the adjuster part ar in the inner joint... and the controllarm are org bend one, instead of a straight one... ( controll the balljoint will fit in the unit outer part ( cone).. the P/N are the same..( last 6 digit)
    • andy10v
      • 5996
      Skull-There are different length ones, I got an URQ one and it was too short to fit my s2.
      The subframes have the mounts in different places.
      I have unseized them before by taking them of and putting them in a vice and using heat. Drop link boots fit the ball joint if it gets torn taking it off.
      The inner bolt can be a pain, soak it in penetrating fluid, and use a good allen key bit.
      Sold ABY-stock
      • Skull
        • 3506
        • Country: Slovenia
        I had them off the car, that was not a problem, but i would like to replace the ball joint and bush (or the whole tie rods).
        I think bambridge is making the delrin bushes for it, is it possible that a front tie rod ball joint would be a straight swap?
        Audi Quattro WR
        • caterpillar
          • 2480
          the rear subframe are all alike: the same P/N ... axept one does have the F or a D after....... so the controllarm will fit...controll the ballunit out by the wheel ( cone)
          • Monkeymagic
            • Mar 2012
            • 3419
            Ive ordered a pair so thats the next task... hopefully the inner bolts will come away
            • Jenks
              • 261
              Glad you're sorted and sorry for the hi-jack but I've three new lemforder ones of these available if anyone else is in need (pm only please).
              Cheers,
              Dan.
              • Monkeymagic
                • Mar 2012
                • 3419
                I wish i knew that before i spent a small fortune. How much you selling them for?
                • Jenks
                  • 261
                  Yeah sorry, I didn't see this till you'd ordered. I've got one on ebay at £75.50 freepost but I'd take £65 'on forum'. I had to buy 7 to get the 4 we needed at a reasonable cost as the only others I could find were on ebay for £199 +p&p for 2!!
                  • Monkeymagic
                    • Mar 2012
                    • 3419
                    The arms arrived today. Jesus talk about overpriced for what they are. The equivalent track control on a4 would be 35 quid.
                    I guess they have you by the short and curlies. I lookforward to a properly aligned car though.
                    Obviously the previous garage lied about doing the 4 wheel alignment.
                    • Jenks
                      • 261
                      Iirc when the motor factors I use could still get them £35+vat is about what they were. They'll most likely have been first line, power train or similar though. I'm sure it was only 18 months since I asked them to check and they could get them then but not 2 months ago.
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        i called andrew page, gsf and ecp they ha a listing but couldnt supply.
