034 Arms and Rear toe adj rods?
  • malncol
    • Mar 2012
    • 288
    • Country: Australia
    Iam running 034 tube arms with the 034 rear toe adjusters , its s2 rear subframe
    question is how much if any clearance between rear toe adj rods and the corner of the subframe should there be ?? also the rods appear to long??they were ordered to suit the subframe with rear sway bar as the rods are different lengths with or without sway bar
    any thoughts??
    thanks
    mal
  • G60Rallye
    • Dec 2006
    • 1321
    I bought some rear tie rods from 034 a few years ago they were also too long. I had to chop them down and run a tap up the right hand thread end. The rods are close to the subframe but they should miss?
