Strut brace on B3CQ
  • John.
    • 2615
    Strut brace on B3CQ
    I'm thinking of fitting a strut brace as per the S2 onto my B3 CQ.
    Depending on the ground that the car is parked on, sometimes the doors don't shut right and this has got me thinking about the strength/rigidity (or lack of!) of the shell.
    My car is very original and as much as I want to keep it so I think that a strut brace would be a sympathetic modification.
    Can anyone tell me if this would be worthwhile doing.
    John.
    Yes it makes a noticeable dfference to the handling, as does adding a rear brace, and a lower brace between the chassis rails
    • _ShurikeN
      • Mar 2010
      • 733
      • Country: Russian Federation
      Think about what You are going to do with the accumulator battery in this case.
      • Tonks4x4
        • Nov 2005
        • 3062
        An original strut brace from an S2 will fit with no clearance issues of the battery and the brake servo. I have done it a few times....
        Tonks4x4 - The Land Rover Specialist
        Audi Nut!!!
        • John.
          • 2615
          Got any details/links to the above?
          Tonks, is it best to seam weld the edge or drill holes and spot it.....how's the S2's done.
          Where's best to get the brackets and what about the brace, S2 item or just buy a bit of square bar?
          Thanks all.
          John.
            Most of the ones I have seen were stitch welded and that is how I did mine.
            The strut brace brackets also fit onto the rear strut towers nicely, or you can use a universal style brace or make one up.
            Lower chassis brace make a nice difference too - have a look at what I did here
            • _ShurikeN
              • Mar 2010
              • 733
              Hm. I didn't manage to install it nicely with usual 175mm height acc battery. Don't You have a photo?
              • Simons
                • Jul 2007
                • 530
                • Country: Spain
                This is what I bough
                More info, parts numbers and price
                • Tonks4x4
                  • Nov 2005
                  • 3062
                  Not a very clear photo.. This one was stitch welded into position in a cabriolet
                  This is one just done on a TYP85 car fully welded
                  Audi Nut!!!
                  • caterpillar
                    • 2480
                    http://www.s2forum.com/forum/showpos...6&postcount=50 THOSE item will fit any audi smallchassi. and vw passat/santana 32b....even the earlyer vw from 74... done in few minuts to weld in
                    • andy10v
                      • 5996
                      A front strut brace is very OEM+, after all Audi decided to do it to the S2s and v6s.
                      You can still buy the brackets cheap from Audi (2 of the same side, but it really does not matter). I welded around the edge when I did my rear one
                      A rear one is easy to do as well. (part No.s for the brackets in the link)
                      I probably have a spare 3B brace (round one, with insulation for above the battery, ABY/V6 are box) if you want it, just need to collect it from Alloa)
                      My rear DIY install
                      Sold ABY-stock
                      • John.
                        • 2615
                        Thanks all for the replies.......going to go ahead with this.
                        Andy, that's a kind offer sir, I can collect.......this coming week?
                        John.
                        • andy10v
                          • 5996
                          PM sent.
                          Sold ABY-stock
                          • John.
                            • 2615
                            Thanks Andy for the brace, collected the brackets,covers and plastic nuts from the dealers today so that'll give me something to do on my days off.
