what size and stiffness coil over springs do you use im using 9 inch at moment but can seem to get car low enough any help more then welcome
coilover spring
60n is the spring rate
60n/mm ~ 342lbin
Helper springs take up the slack so you can run a shorter spring and it does not unseat when the suspension is unloaded: the second skinny little springs at the top. when the suspension is loaded they bind and the main spring does it business.
Imola B6 S4 AvantComment
