S2 (Avant) and 80 quattro suspension
  • Jack4688
    • May 2010
    • 1004
    Did a quick search but can't find the answer I'm looking for.
    Is the rear suspension - wishbones, uprights etc - the same for an S2 Avant as the B4 80 quattro?
  • caterpillar
    • 2480
    what year are you talkin about
    • Jack4688
      • May 2010
      • 1004
      Well I have a 1993 S2 Avant and am possibly going to be purchasing rear suspension components from a 1995 80 quattro
      • caterpillar
        • 2480
        dont think the part are interchangabel.. without major rebuld, and some weldin... i will NOT go for this..BUT i think ive seen some cars with rear end( called competition, or like that) read; some cars are thrue one year in front end, and the newer parts in the rear end( called GT or sport verson)
        • driftin jo
          • Sep 2007
          • 2222
          As far as I know they are identical
          • Doc_brown
            • Aug 2013
            • 35
            yes
            same as b5 quattro except 5 stud
            • Skull
              • 3506
              • Country: Slovenia
              Identical indeed...
              Audi Quattro WR
              • Rusty
                • 18953
                If you're talking springs and dampers then although they will fit, the S2 runs stiffer and lower springs and uprated dampers as standard and aftermarket kits are different rates & heights also. Hubs are different (4 stud) and thee nay be a few drive line differences related to that too.
                • shaun5
                  • 1610
                  Jack is looking to buy my B4 80 quattro saloon rear axle parts, its the top and bottom wishbones and uprights (the bits that hold the wheel bearing) As far as I was aware all of those parts are interchangeable, obviously the hubs are different.
                  • Jack4688
                    • May 2010
                    • 1004
                    Yes I was aware that the hubs are different and my car already has non-standard springs/dampers.
                    Thanks for the words of wisdom chaps
