Kerbs and wheels dont mix!
  • Glen Chamberlain
    • 375
    Well it all started like, er well, ah, um well never mind too much what happened but the rear O/S wheel kissed a 45 degree kerb and, well it doesn’t look to run the same as the other side no more! Damm! I have look at the suspension and there is nowt obvious, no stress marks in the paint no bolts that looked to have moved or owt really? I had it on the ramp today and decide I need to try to get it to visually match the other side before I kill the tyre completely. (It's not as bad as you think its not all twisted or owt but under carefully inspection from a distance it can be seen) Iam gonna get it on the 4 wheel aligner when I get time but it's just a temporary fix iam after. I found the rear cam washer on the track rod arm to be missing its locating lug, so that’s a job for Monday! Can anyone with an avant give me the measurement from the inner if the rim to rim for both rear wheels so I can try and get it closer? Or if anyone happens to have some miracle drawings and measurements of the suspension set up that would also do!!!!!!!!!
    Oh and completely off the subject! what does IMHO an BTDT mean or some thing like that anyway?
    Money is everything! Second to Power of course!!! But money breeds power??
  • Doug_RS2
    • 3847
    Re: Kerbs and wheels dont mix!
    I think
    In My Humble Opinion
    Been There, Done That
    • Glen Chamberlain
      • 375
      thanks
