Subframe bushes replacement-advice needed
  • piotr
    • Jul 2012
    • 1470
    Hi guys. I finally found time today to fit new bushes to my subframes. I thought it will be a easy job but now I'm asking you for help guys. The problem is -the bush just doesn't want to go in. I have used plenty of lube but when i start to push it in all it happens is that the bush is started crashing.it just looks like the rubber lip on the top of bush is too large but it is definitely the right part number. Could you please advise me guys if there's any special tools req.to do this job and if anybody else had had the same problem.many thanks-Pete
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Are they poly bushed or OEM type? I would assume OEM may require a press as they are a very very tight fit!
    1996 S2 ABY Silver
    • Bowie69
      • Nov 2013
      • 2675
      If OEM, then you won't get them in easily, they are sort of top-hatted both ends, so need a fair amount of pressure to get over that initial hump, that and lube so they don't tear.
      One reason I went polybush.
      • Colesy
        • Feb 2009
        • 2980
        You should be able to do it without a press, maybe with a bolt and plenty of lube.
        There a guide here: http://www.s2-audi.co.uk/tech_articl...r_subframe.htm
        Explanation for fitting the new ones is quite brief but might help.
        • piotr
          • Jul 2012
          • 1470
          They are OEM bushes.i used pleeenty of lube again,used press and its start to tear off the rubber lip.not sure what to do next?
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            Hammer?
            1996 S2 ABY Silver
            • piotr
              • Jul 2012
              • 1470
              Maybe not yet
