Can anyone tell me where i can source these from as i have just spoke to german and swedish and GPC and they say they dont stock them. Is this the right term for them or are they called ARB arms etc. Maybe a case on main dealer?.....
3B S2 ARB Drop links?
Andy,
yep!
i'd do the front and rear in pairs, you can normally tell if they need doing cos you'll have front and rear end creaking through the suspension, if i remember especially at low speed. Dead easy to change though might be worth soaking the current ones in something to make it easier to get them off. Should make things a bit tighter and the steering feel better too
HTH
Davidsigpic
1992 3b S2 Coupe
Originally posted by porkkisAdjustable links? Why in earth?
You use the adjutable links to eliminate preload in the ARB. The ARB should be final mounted to the links with the car on the deck or ramp. This way the bar does not hang. The adjustable link allows you to set the ends so they just slide into the mounting holes without having to put load on the bar, to get the holes lined up. Preload.
Also, install with person in the drivers seat. Just like with an alignment.
GregThey can have my car when they pry my cold dead fingers from the steering wheel.
Originally posted by 90quattrocoupeYou use the adjutable links to eliminate preload in the ARB. The ARB should be final mounted to the links with the car on the deck or ramp. This way the bar does not hang. The adjustable link allows you to set the ends so they just slide into the mounting holes without having to put load on the bar, to get the holes lined up. Preload.
GregJoe "NoNonsense"
axis motorsport
joe@axismotorsport.com
I made custom droplinks as I used a front 20V ARB on the rear. It just so happens they are adjustable - not that they needed adjusted - if you need to tensionthe ARB, you should really look into what is not true on your suspension first.
Custom droplinks don't cost too much to make. Get standard metal ones. cut a bit out he centre shaft - thread the 2 ends - get an internally threaded bar and you have just made your own - easy. Or you can buy the ends and make a fully custom one.Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
