I sort of already have the answer for the following question, but wanted to make sure, as there are quite a lot of people on here that have done builds etc.
FWD C4 front suspension will fit URS4, struts, subframe, wheel bearings etc?
And, let's say any C4 Quattro's rear suspension will fit URS4?
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDI
The rear definately yes. But the front I'm not too sure, I think the offset of the UrS4 parts could be different to make for a wider track at the front.
Thanks. I was just checking out the vagcat, and all the parts came up to be the same for AAN and FWD ABC engine cars, so I am not sure.
'93 Audi UrS4 Avant
Sorry to dissapoint but none of your fwd stuff is the same as 4wd S4. I posed this question myself and tried to compare 2.8 C4 A6 quattro to C4 S6 A6 and only a few parts on the rear are the same ie track rods and links.
Not good news at all Not surprised that people say those cars are not cheap. Back to drawing board.
Do you know the title of the thread you made? Would like to know how it is different.
By the looks of it only things I can use is subframe, shocks(mounts etc incl.) and track control arms, that's about it. So Quattro stuff fits Quattro, whereas FWD only couple of things will fit Quattro.
'93 Audi UrS4 Avant
