Symptoms of worn topmounts??
  • s2carlo
    • 252
    I was wondering whether I have worn topmounts on my 1991 3B or not.
    I would therefore like to know what the symptons would be so I cna compare with my situation.
    How could I check / verify the fact?
    thanks in advance
    Carlo
    No power, no glory!
    S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
  • horvathg
    • Dec 2003
    • 556
    I am also interested in this so please someone say something.
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
    • gavs20v
      • Sep 2004
      • 3057
      When youve got the wheels on the ground and the bonnet open, pop the plastic dust covers off the strut tops. Get a mate to wiggle the steering wheel and see how much movemnt is in the mount itself, also how far the metal cap protrudes above the strut top is a good indication.
      HTH
      Nice one
      Gav
      S2 Cabriolet.........
      • audiman
        • 4827
        how far does the metal cap protrude then on good mounts and on failed mounts.
        Im sure the car tends to tramline badly too when the mounts are shot
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • s2carlo
          • 252
          Good question Audiman, was mine too.
          What's to tramline???
          Thanks
          No power, no glory!
          • audiman
            • 4827
            Try this, very good explanation
            http://www.tirerack.com/tires/tirete...tramlining.jsp
            Audi UR Quattro
            • gavs20v
              • Sep 2004
              • 3057
              Definitely agree with the tramlining,picks up all the various different cambers in the road, also just generally feels odd (lol, very technical). I always thought goosed top mounts sat at an awkward angle and poked out through the turret more,
              Gav
              • dan_b
                • Sep 2003
                • 3670
                Thanks for this excellent question, I've been wondering the same. I'll check mine tonight - I'm getting tramlining now in my 3B, plus a few creaking noises so something's definitely worn, but good to know how to diagnose the parts.
                • S2 Ant
                  • 3682
                  I actually bought some new ones for mine the other day from GSF.
                  Didnt get around to fitting them in the end as we ran out of time doing other bits but will do it later in the week or next week i think.
                  Ant
                  2011 Kawasaki Z1000
                  • s2carlo
                    • 252
                    Can the topmount swap easily be done by myself or do I need special tooling??
                    Is there some workinstruction??
                    Maybe you coould make some pictures and description while swapping?
                    No power, no glory!
                    • S2 Ant
                      • 3682
                      Not the easiest of jobs, will need to remove the structs to do it, so need spring compressors etc..
                      Also unless you're very accurate at marking everything up you will need to have the alignment checked after also, to check camber settings.
                      Ant
                      2011 Kawasaki Z1000
                        You can change the top mounts without removing the struts.
                        If you use a set of spring compressors and then undo the top mounts you can undo the notched nut in the top mount and change them and bolt them back up. You need two people to do it though.
                        Also if you remove the strut you need to undo 2 x 8mm bolts holding brake pipe bracket on.
                        13mm bolt that holds the ARB drop link in, 17mm for the steering arm. Then two bolts holding the strut on are about 21mm and 22mm from memory. Doing it this way wont affect the alignment but its still worth getting it checked after.
                        • S2 Ant
                          • 3682
                          Ah excellent, thanks for that Greg, might have saved us more stress LOL
                          Those small brackets you speak of for the brake pipe we sheared off, crappy things LOL.
                          Still need to work out whats loose on mine for it to do what its doing.
                          When moving the steering wheel there is a knock when it turns and this happens in both directions on initial movement, sounds like somethin has too much play in it, but cant work out what.
                          Ant
                          2011 Kawasaki Z1000
