So I recently refreshed my 90 coupe with a pile of new bushings and upgrades along with a pair of swaybars. After finishing a long road trip with some very twisty very tight corners I find myself happy with what I have, but wanting more at the same time.
Car has 034 Al subframe bushing all around
034 track density transmounts
034 track denisty poly diff mount
new tierods in rear
new OEM control arm bushings all around
new ball joints
RS2 FARB
and a 25mm control arm mounted RARB
Car is setup for rally-x events so it's ~1/2-3/4" taller then stock, but even as it is the car is tight in the corners, very neutral, but I would like a little more tail snap to help it rotate. Is there any options i can do either alignment wise or component wise to get the rear to come around (power isn't an option since it's still a NA 7A at the moment).
TIA
new tierods in rear
new ball joints
RS2 FARB
TIA
