Strut to hub bolts
  • mikey-mk
    • May 2014
    • 24
    Strut to hub bolts
    Hiya everyone.
    So I'm after the above, for an Audi 80/90 quattro and the ascociated nuts (hexagonal head bolt BM12X1,5X74 and hexagon nut, self-locking M12X1,5).
    Now I've just been informed by good old TPS that they no longer produce them and have not been superseeded.
    Can anyone recommend a supplier? Or source of them.
    Regards.
    Michael.
  • caterpillar
    • 2480
    any hard ware shop DOES have normal screws and nut.... they are 10,9 strength, but they does have 12,8. too... umbrako, or znx... iv have the normal 6 std head in my car..
    • mikey-mk
      • May 2014
      • 24
      Thanks for the reply fella.
      There is a place here in Milton Keynes, though it's only open 9-5 Monday to Friday. Which is when I'm at work.
      The other hardware places we have, don't really cater for high tensile bolts.
      So was hoping for a recommended online suggestion.
      • Mikes2
        • 1704
        You need to be aware that these are stretch bolts.
        Mike
        http://www.s2-audi.co.uk
        • sidrick
          • Jan 2011
          • 1342
          Originally posted by Error404
          Sorry to hijack Bo, but i have run into this NLA bolt issue, and found that N 0101835 is the rear wishbone to subframe bolt from the B5 quattro platform - also an M12 x 1.5 x 75 and AFAIK also a stretch bolt - any reason we can't use that for the 3B hub to strut bolts?
          This is the bolt I used on my 3B last month. It's spot on and available from Audi.
          • mikey-mk
            • May 2014
            • 24
            I was always told to replace them as they were stretch bolts.
            Nice one, i didnt fancy trawling vagcat for an equivalent or try to explain to the staff at TPS what i was after. They only do part number or reg, not thinking there.
            I owe you Sidrick.
