urS6 - Coilover Suspension kits ?
    As per the above, please advise of any suggestions for off-the-shelf kits for a urS6 Avant ?
    Thanks for any assistance.
  • Thuppu
    • 4115
    KW Variante 1, zink coated front struts, stainless rear. You have to send out you own struts for modification. Quite expencive considering that they are made of your old ones.
    FK Köningsport, zink coated fronts. Uses Koni shocks. You have to send your old ones for exchange. Can be some issues with the shocks. Long time ago there was some fails with these, and the shock cartridge was same part number as used in Opel Corsa... so you know, it can't last for long.
    FK standard, no brand shocks. Old ones for exchange.
    And then there are these cheap TA-technics, Supersport etc. conversion kits on ebay. No brand shocks and so on.
    • andy10v
      • 5996
      Also 2bennett
      Audi service, restoration, performance upgrades, parts and more. 2Bennett is a convenient and cost effective dealer alternative for all Audi years and models. Our 25 years of total focus exclusively on Audis means we understand how to diagnose and repair your Audi like no other. Extensive breadth of diagnostic resources and knowledge, from early examples to newest Audi models. Audi diagnostic equipment as well as parts access directly with Audi USA and Germany helps ensure efficiency and accuracy.
      Sold ABY-stock
      • philj
        • Feb 2010
        • 377
        I will be able to offer something for the C4 once I finish the set for mine, will be a couple months. Strut length and preload adjustable, separate bump/rebound with external reservoir options.
          Is it too soon for any update ?
          Thanks either way, still interested.
