You should be able to make a puller that will pull the bush out, as long as the press part is low enough profile you should be able to do it by just dropping the front, then back of the subframe
Something like Mike's home made tool
It is only 4(?) more bolts to drop the subframe once the subframe bolts are removed though........
Outer ball joint pinch bolts
Gearbox mounting bolts
