Hi guys.today i took my Coupe ABY for road test -first time after big rebuild and i feel vibration from about 25mph.
i think its mainly from the back but not sure.
i have got all new shock absorbers/lower arms/ball joints/all nem diff and gearbox mounts/prop centre bearing/all drive shaft uj-s streaped,cleaned and new grease/new clutch/new wheel bearings etc etc.
i suspect it might be something to do with drive shafts,prop,rear diff but what do you think guys?i swapped wheels of different S2-its still there.is the drive shafts or prop need balancing after streapping?
i think its mainly from the back but not sure.i have got all new shock absorbers/lower arms/ball joints/all nem diff and gearbox mounts/prop centre bearing/all drive shaft uj-s streaped,cleaned and new grease/new clutch/new wheel bearings etc etc.
