Strut to hub bolt
  • mac2226
    • Jun 2008
    • 1289
    Strut to hub bolt
    Am I right that all s2 coupe aby have m14 stretch bolts, do I measure the bolt holes? Or should I measure the thread? Bit confused as I need to know to order my kw coilovers please can somebody tell me what to measure
    N 90624401
    M14 x 1.5 x 75
    2 per side
      If your OE struts are still fitted, you can measure the diameter of the bolt. Measure both sides to be sure.
      • caterpillar
        • 2480
        THATS correckt... but som of the cheaper models does also have the m12....( 2,3 NG or some diesel versons.. they does also have the smaller bearing (75mm)
        • mac2226
          • Jun 2008
          • 1289
          Originally posted by UrS4boy
          N 90624401
          M14 x 1.5 x 75
          2 per side
          Thanks urS4boy will order this bolt and take one out each leg and try the new bolt and hopefully it's a m14
            N 90624401 was pulled from the catalogue for a 1994 ACOQ and specifically for the 3B, AAH, NG, ABC and ABY engines. Most of these use the hub carrier for 82 mm front wheel bearings. But that said, there is no special call-out for the bolt for the 75 mm bearing hub carrier, i.e. they should both use the N 90624401.
              In this case KATE can't be trusted and a vernier is your friend. The bolts changed from m12 to m14 without a chassis number break point, some people even have M12 on one side of the car and M14 on the other. Easy / quick way is to remove the wheel and measure the bolt protruding through the nut, no need to remove or order anything
              • mac2226
                • Jun 2008
                • 1289
                Yes error that's another way but I've just measured a spare one in my garage which I replaced not so long back so yes it's m14x1.5 thanks every one for help now I can order my kw variant 3
