Anyone done this? Guessing that the 3 bolt design is stronger / stiffer than the 2, so just looking in to using some spare pressed items.
Front wishbones on the rear - coupe
I've always wondered about this but never got around to taking any measurements, figured there must be a reason no one fit's the forged arms to the rear
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
RS 2 580HPComment
i did it. moved the subframe back, moved the diff forward, some fiddling about with things til it all went back together. or maybe it was subframe forward, diff back. to keep the driveline in there and move the mount points of the LCA's.
No I have standard arms on my S2, I have currently got the cast arms on the shorty, however it moves the wheel 5mm to 7mm further forward in the wheel arch.
I will be changing them to the sport quattro ones once they are finished.
To continue to use the cast ones on the rear speeding G60 is correct
subframe back, diff forwardComment
