Not exactly hard to find or expensive: http://www.ebay.co.uk/itm/MEYLE-HD-F...item564c216065
Best top mounts
Best top mounts
Got them sorted thanks a Tenner each plus VAT delivered what do people recommend for the back GFS have some made by somebody called vtec yes I've never heard if them either will probably put oem blue ones in the rear unless somebody has any better ideas
Sent from my iPhone 5
using TapatalkABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
Next 6 months depending on getting the preproduction prototypes sorted and tested for fit.
Don't expect much change from £300 a pair including bearings. Cheaper than importing the equivalent from the states and should be bomb proof compared to the cheaper options with none of the issues with keeping them tight.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
I have started to work on top mounts + increasing caster. Still some job to do but.... Bearing housing I used can be also welded directly to original suspension tower. Bearing is quite much bigger comparing to most caster/camber plates. It have also grease nipple in it. Bearings, housings, nuts bought from rallyrace.fi. Plates cut by local laser cut shopLast edited by hiloran; 15 September 2014, 18:53.Comment
