ABY Power Steering Pump Belt
  • ash2050
    • Jun 2012
    • 255
    Has anyone got a guide on how to replace the Power Steering belt on the ABY?
    Does the front bumer need to come off?
    Also, does the Alternator belt etc need to come off for removal of the Power Steering Belt?
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Front bumper doesn't need to be removed.
    You slacked off the bolts on the pump and the thread bolt on the tensioner.
    The alternator belt will need to come off to allow the belt past. Your best to renew both if your in there.
    Then reapply and tighten.
    Rough guide. But be plenty guides on here
    • JuizeR
      • Jan 2010
      • 28
      Could someone take a picture from the tensioner bracket and how it is mounted on the pump?
        I’m not near the car atm but there is an adjusterboltvto tension the pas pump next to the inlet manifold
          • Dec 2017
          • 5984
          See what I can do.
            • Dec 2017
            • 5984
            • JuizeR
              • Jan 2010
              • 28
              So the lower part attaches to waterpump bolts. Thanks!
