RS2 Drop Links
  • blu_s2
    • 392
    RS2 Drop Links
    Guys any BTDTs...
    As I'm about to change the drop links on my Coupe, is it worth moving to the metal RS2 front drop links in place of the S2 plastic ones.
    Any handling or fitting issues?
    Jim
    Jim,
    Might be worth having a word with QRSports because they do rose jointed ones which are ment to have less slop than the standard drop links.
    Mine had metal ones fitted before so i fitted those when i changed them last year, the look to be a bit tougher than the plastic ones.
    • s2driveruk
      • 12696
      metal all round on mine too, changed them a while back (were from GSF) and they have been fine ever since, no more low speed bloody creaking :LOL: was driving me insane
      1992 3b S2 Coupe
      • blu_s2
        • 392
        Greg, thanks I spoke to Chris @ QRSport but he did warn their metal ones are more suitable for track use than everyday road use. So I thoght I'd take a look at other options.
        Thanks
        Jim
        • blu_s2
          • 392
          David, are these listed as S2 or RS2 parts?
          Jim
          • s2_southwest
            • Oct 2004
            • 823
            When fitting the metal drops to an s2, dont you need to upgrade to the rs2 antiroll bar? thought i saw that posted somewhere, im probably wrong though!
            Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
            • Mikes2
              • 1704
              No, the metal drops are a straight fit. S2s up until 1994 all came with the metal drops as standard.
              You'll need 4 new lock nuts. The old ones tend to get mashed when you remove them.
              8A0 407 465 C is what you're after.
              Mike
              http://www.s2-audi.co.uk
              • blu_s2
                • 392
                Cheers Mike, is that the same part no f+r?
                Jim
                • Mikes2
                  • 1704
                  No, that's only a front part number. Haven't done the rears so don't know the number. It's a slightly different setup at the back.
                  Mike
                  • s2driveruk
                    • 12696
                    Jim, there is a post somewhere on the forum from me with the gsf part numbers - cant remember them offhand but if you dont find them let me know and I can dig them up on the old receipt. IIRC the gsf ref is a 5 digit number
                    1992 3b S2 Coupe
                    • blu_s2
                      • 392
                      Thanks again guys, just in case anyobne else follows this thread in months to come here's the link to the gsf part no.s.....
                      Jim
                      • GeorgeS2UK
                        • Oct 2004
                        • 225
                        • Home: England
                        I am assuming that these are the Powerflex poly bushes required the finish the job (RS2 FARB)
                        And there is a drawing to go with if if you click the drawing tab
                        91 S2 3B in Pearl, Miltek, De-Cat pipes, Short Shifter, 996 Monoblocks + 323 A8 Discs, Whiteline R-ARB:MRC Generic 3B Chips
                          they are quite expensive for what they are, i think they are £14 each for the RS2 ARB bushes!
                          • Technogym
                            • Dec 2004
                            • 200
                            • Country: Norway
                            Hi Guys!
                            Since this thread ended up in the famous polyflex bushes and pricing, could anyone tip me from where to get the best price. Want to change the 4 ARB, All busshes, diff mount. I have seen in one thread some months ago that it was ARB s that was adjustable, is this to preffer??
                            Vegard
                            • Beetie
                              • Oct 2003
                              • 1517
                              Mines a 93my and has plastic ones
