Quick (and hopefully easy) topmount question
  • Quick (and hopefully easy) topmount question
    Can anyone tell me if the rear topmounts are the same part as front topmounts - car is a 93 Coupe 2wd 16v.
    I've got a pair of Meyle HD for the front (thanks Yaz) and I'm trying to suss out what I need for the rear.
    Thanks in advance!
    Same on a quattro, fwd is different at the rear
    FWD rear suspension
    Front suspension
    Sold ABY-stock
      Cheers for the info mate. Don't suppose you can find the Audi part no. for the rears? I haven't had much luck with Google!
        Part numbers for the diagram from vagcat
        1 893500047M
        rear axle beam / F >> 8B-L-003 810*
        (1) 8G0500047
        rear axle beam / F 8B-L-003 811>>*
        (2) 8D0501117C
        stub axle / also use:
        8D0 501 641 A /
        - 8D0501641A
        oil seal
        3 N 90415404
        allen key head bolt (combi)
        M8X22 /
        4 357501641B
        oil seal
        5 311405625F
        taper roller bearing / LEICHTLAUFLAGER
        29X50,29X14,73 inner /
        6 443614149A
        rotor for speed sensor / for models with anti-lock brake system -abs-
        7 8A0501653B
        wheel hub
        4/108 /
        8 443615601
        Brake Disc
        245X10 4/108 /
        9 211405645D
        19,05X45,237 /
        10 431501219
        washer
        11 N 0111671
        hexagonal nut
        BM16X1 /
        12 803501221
        locking ring
        13 N 0125361
        split pin
        4X30 /
        14 8D0501249
        cap
        15 895505173A
        panhard rod
        16 431505172
        rubber mounting
        17 N 0101654
        hexagonal head bolt
        M12X1,5X65 /
        18 N 90635001
        hexagon nut, self-locking
        M12X1,5 /
        19 N 0101573
        hexagonal head bolt
        M12X1,5X140 /
        20 431505193A
        washer
        21 N 90635001
        M12X1,5 /
        22 811511247
        bonded rubber mounting
        23 N 90061302
        hexagonal head bolt
        M12X1,5X70 /
        24 N 0115317
        washer
        A13X24X2,5 /
        25 N 90635001
        M12X1,5 /
        - 811511423A
        rubber mounting / for stabiliser:
        rear /
        26 893511115D
        coil spring / 1 paint mark
        green / 3-speed automatic: 3A,AAD
        (26) 893511115J
        coil spring / F >> 8B-L-003 810* / 1 paint mark / 1 paint mark
        silver yellow /
        (26) 893511115AB
        coil spring / F 8B-L-003 811>>* / 2 paint marks
        yellow /
        (26) 895511115A
        coil spring / for sports-type running gear / 2 paint marks / 3 paint marks
        pink blue / NG,6A,ACE
        (26) 895511115A
        coil spring / 2 paint marks / 3 paint marks
        pink blue / AAH,ABC
        (27) 893513031AE
        gas-filled shock absorber
        (27) 893513031AF
        (27) 895513031D
        gas-filled shock absorber / for sports-type running gear
        / NG
        (27) 895513031D
        / AAH,ABC
        28 N 01047310
        hexagonal head bolt
        M10X75 /
        29 N 0211955
        M10 /
        31 893512103B
        spring disc
        lower /
        32 811512113
        damping ring
        upper /
        33 893512115
        washer
        34 811512119
        ring
        35 893512127
        protective cap
        36 893512131
        stop buffer / F >> 8B-L-003 810*
        95X52 /
        37 893512131E
        stop buffer / F 8B-L-003 811>>*
        84X46 /
        38 171512135
        cap
        39 893512137
        boot
        40 811512333A
        bearing ring
        lower /
        41 811512335A
        bearing ring
        upper /
        43 861513279
        disc
        44 N 0211984
        M10X1 /
        45 4A0598625A
        Sold ABY-stock
          Excellent - much appreciated!
