G002000
  • mike74
    • Apr 2014
    • 615
    G002000
    Morning chaps,
    I discovered that one of the hoses at the bottom of my hydraulic reservoir has been weeping slowly for quite a while and as such, I now need a top-up of fluid. The writing on top of the reservoir says to use G002000 fluid which, I've found at Halfrauds. The back of this bottle clearly states this spec and that it is SYNTHETIC fluid. I've done some digging around and have found various conflicting statements about mixing mineral/synthetic fluid of this grade and whether or not its a good idea. I don't know what the fluid in my reservoir currently is, there's my dilemma. (no evidence in vehicle history to indicate its ever been flushed/replaced, just topped up)
    Personally I would have thought that as long as a given fluid conforms to G002000 then, it should be mixable with any other fluid conforming to that grade?
    What are people's thoughts on this? I really don't want the expense and hassle of replacing all the fluid if I don't have to but, also don't want to bork the rack and pump!
    Or am I just getting myself in a knot over semantics?
    cheers for now,
    mike
    Go get a bottle of G004000 (superseded G002000 some years ago) from the dealer it's not expensive it's about £8. They will have it on the shelf. Use the right stuff
    • mike74
      • Apr 2014
      • 615
      Cheers Alex
      Would it have to be Audi fluid or would any G004000 spec fluid be ok to use?
        Just use Audi stuff. It's not expensive
        • mike74
          • Apr 2014
          • 615
          Sorted! Spoke to a specialist indy garage (ex Audi tech) not far from my house and they're going to top it up for me with the correct stuff
          ...or at least it better be!
