Hello friends,
I am in process of rebuilding suspension on my RS2 and i have a problem with my rear struts. They are coilovers from KW and the bottom bushing had slipped out of the shock on both sides.
I managed to press it back in but it got damaged too much due to fact that it was not centeres for while.
It is strange that this happened in first place but in any case i need to do fix it as the coilovers are still in working order.
I contacted the KW already to see if they can help me out, but i was wondering if someone knows if there is other solution.
Here is pic also after i pressed the bushing back in, but as pic shows its no good
Thanks in advance for input
